Campus Switching and Routing
Occasional Contributor I
HP 5400ZL Issues added vlan
We have an 5400zl switch. We added a new VLAN with an IP address (10.217.150.254/24). Unfortuantely we can't ping the default static route (0.0.0.0 0.0.0.0 10.217.255.1). Between the VLAN's we can normally ping. All other VLAN's can reach the default static route. The new VLAN is in the ip route. Any idea's?
Thanks!
Contributor I
Re: HP 5400ZL Issues added vlan
I guess its the same as at comwware that minimum one interface in the new vlan must be up, to bring the vlan up
RE: HP 5400ZL Issues added vlan
Please check if there is routing for 10.217.150.254/24 on the GW(10.217.255.1)
