Campus Switching and Routing
Contributor II
HPE/Aruba 2530 with external CaptivePortal/EWA Server
Hi there,
I have a Aruba 2530 switch with the newest release and I would like to see the external captive portal from Clearpass running for web based auth using wired ports.
The command for the 2530 seems to be:
aaa port-access web-based ewa-server 10.1.2.3 "/guest/login.php"
It will end in a loop if I connect to this. Seems that those switches only support html and no php.
While using a webserver with html, it is working fine. I would like to get this running with Clearpass Guest CaptivePortal
Any idea how I can get this running with Clearpass, which is php?
Regards
Sven - AMFX #35
Re: HPE/Aruba 2530 with external CaptivePortal/EWA Server
Take a look at the ProCurve / ClearPass TechNote. The redirect URL needs to be sent back from ClearPass.
Tim Cappalli | Aruba Security TME
Contributor II
The technote isn't listing external captive portal/EWA server. I only find internal captive portal with external authentication
Sven - AMFX #35
