Campus Switching and Routing
VM
IRF Stacking on 5500 & 5510
Hi All,
I want to ask about IRF Stacking on 5500 and 5510.
Since we know that 5500 has been end of sale, so we migrate to the recomended replacement (5510).
Currently we have 5500 and we want to add another 5510 because we can't purchase for 5500. Can we do stacking on it with other method? I've check on IRF Compability that 5500 only works with 5500 and 5510 only works with 5510.
 BR
Re: IRF Stacking on 5500 & 5510
Hi
At the moment NO families can be mixed. You need switches from the same family.
I attached a document that validates it
Regards
Everardo
