Campus Switching and Routing
Occasional Contributor I
Issue connecting to the router on different VLAN
I am trying to setup VLANs on our network.  I am having trouble with any client that is not on the same subnet as the router.   I have VLAN 99 and 100.  The router IP is located on the subnet for VLAN 99.  Any client on that subnet can ping the router.  However, any computer on VLAN 100 can not pint the router.  They can ping other clients on VLAN 99 just not the router.  I have tried two different routers one is a Netgear and one is an Adtran.  The Aruba switch I have is a 2930F.  Below is my config and I have attached a Visio diagram of the setup.  Any help would be greatly appreciated.
; JL256A Configuration Editor; Created on release #WC.16.05.0004
; Ver #12:08.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:ba
hostname "switch 1"
ip route 0.0.0.0 0.0.0.0 10.63.1.2
ip routing
vlan 1
name "DEFAULT_VLAN"
no untagged 1-4,13-16
untagged 5-12,17-52
no ip address
disable layer3
exit
vlan 99
name "Server"
untagged 1-4
tagged 52
ip address 10.63.1.1 255.255.252.0
exit
vlan 100
name "client"
untagged 13-16
tagged 52
ip address 10.63.4.1 255.255.252.0
exit
Re: Issue connecting to the router on different VLAN
Greetings!
The routing configuration on Switch 1 appears correct (routing enabled, static gateway pointing to Router 1).  Does Router 1 have a route back to 10.63.4.0/22 pointing at 10.63.1.1 as the next hop?
Matthew Fern | Technical Marketing Engineer, Campus Networking
Aruba, a Hewlett Packard Enterprise Company
No I don't. I have the same basic setup at several branch locations using a Cisco SG300 and I have never had to make a change on the router. I will give it a shoot and see if that does the trick.
Art Estes, Network Administrator
MCSE, MCP, Network+, A+, CCNA
(804) 521-4999 | Art.Estes@goodwillvirginia.org | www.goodwillvirginia.org
[cid:image001.jpg@01D3C28A.F65AFD70]
In Central Virginia: (804) 745-6300 | 6301 Midlothian Turnpike, Richmond, VA 23225
In Coastal Virginia: (757) 248-9405 | 1911 Saville Row, Hampton, VA 23666
[cid:image002.jpg@01D3C28A.F65AFD70][cid:image003.jpg@01D3C28A.F65AFD70] [cid:image004.jpg@01D3C28A.F65AFD70]Creating Pathways to Work - With You
Adding the static route worked to 10.63.1.1.  I would like to understand what the Cisco SG300 does that allows VLAN on a different subnet than the router to access the internet without the static route statement.
