Campus Switching and Routing
Occasional Contributor I
POE on aruba Switches
How do i enable POE on all ports of the Aruba Swith? Right now i can only get poe on a specific vlan.
Re: POE on aruba Switches
I'm not sure I understand, PoE is enabled per interface/interface-group not per VLAN. Can you share a copy of your configuration?
You apply a poe-profile either to an interface or interface-group.
Best regards,
You can assign the initial poe profile to your interface group to enable POE for those ports.
poe-profile "poe-factory-initial"
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
That did it thanks
