Campus Switching and Routing
Contributor I
PoE Switch
If I wanted to connect my IAPs to a basic PoE switch, would I be looking at your Mobility Access switches?
Re: PoE Switch
Yes, there are 3 lines:
S1500
S2500
S3500
This datasheet offers a good overview of the differences.
http://www.arubanetworks.com/pdf/products/Matrix_MobilitySwitches.pdf
The MAS integrates with the Instants for things like rogue AP detection and VLAN trunks. You can also manage both the Instant and switch from the Airwave management system.
Tim Cappalli | Aruba Security
Contributor I
Re: PoE Switch
Yes, usually i use 2530 for connecting IAP
Frequent Contributor I
Re: PoE Switch
Weren't S1500/S2500/S3500 announced as end-of-sale last year?
Contributor I
Re: PoE Switch
Yes, that switch end of sale at 31-Dec-16
Trusted Contributor I
Re: PoE Switch
and that is why bringing a thread originally from 2014 back isn't a good idea :)
