Campus Switching and Routing
Contributor II
S2500 CONGIT ARUBA 6000
im trying to configure a S2500 switch with an Aruba controller 6000, as i understand the MAS work as an AP and i want to see the MAS on the controller and create roles and authentication per port on the S2500.
The port GE 0/0/17 is connected in the VLAN 5 in access mode where is all the management ip of all the campus AP's and tunelled mode  to the controller.
The config is:
interface-profile switching-profile "UNI"
   access-vlan 5
interface-profile tunneled-node-profile "default"
   controller-ip 10.225.1.150
interface gigabitethernet "0/0/17"
but i dont see it in the aruba controller as an AP, what do i need to see it in the Aruba controller??
The objective of this demo is connect wired users and apply roles and dinamic VLANs by 802.1x
Any suggestions?
Re: S2500 CONGIT ARUBA 6000
Do you see it under "Wired Access Points"?
Can you run show tunneled-node state and show tunneled-node config on the controller?
Tim Cappalli | Aruba Security
Contributor II
it not see under wired access points
the output:
(aruba-master) #show tunneled-node state
Tunneled Node State
IP  MAC  s/p  state  vlan  tunnel  inactive-time
(aruba-master) #show tunneled-node config
Tunneled node Server:Enabled
Tunnel Loop Prevention:Disabled
in the log i see this:
(aruba-master) #show log all | include  00:1a:1e:0f:7e:40
Aug 15 13:29:23  stm[1824]: <304001> <ERRS> |stm|  Unexpected stm (Station management) runtime error at mux_harvest, 1315, Heartbeat Timeout 00:1a:1e:0f:7e:40 S2 P30
Aug 15 14:28:15  stm[1824]: <304001> <ERRS> |stm|  Unexpected stm (Station management) runtime error at mux_harvest, 1315, Heartbeat Timeout 00:1a:1e:0f:7e:40 S2 P29
The MAC 00:1a:1e:0f:7e:40 is from the S2500, any suggestions?
Regards
Aruba
Can the Mobility Access Switch ping the Mobility Controller? Can you attach the configurations files from the MAS and MC?
Best regards,
Madani
