- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
S3500 Mobility Switch Not Showing Transceiver
01-31-2018 01:50 PM
Greetings,
I have a S3500 48 port switch that was already in production. I added a 4x10GB module in order to replace the uplink to the core switch with a 10GB fiber jumper.
The module will not recognize two transceivers that I have tried. I know these transceivers work, because I went ahead and used them in other S3500 and S2500 switches.
This is what is shown when I run the show transceiver command:
_____________________________________________________________________
Port VendorName VendorSN ArubaSupported CableType
This is what I see no matter which transceiver I use.
This is what is shown when I run the show detail command for the interface:
(LCA-L207-01) #show interface gigabitethernet 0/1/0
GE0/1/0 is administratively Up, Link is Down, Line protocol is Down
Hardware is Gigabit Ethernet, Interface is GE0/1/0, Address is 00:1a:1e:1e:f8:32
Encapsulation ARPA, Loopback not set
Configured: duplex (N/A), Speed (N/A), FC (Off), Autoneg (Off)
Interface index: 129
MTU 1514 bytes
Link flaps: 0
Flags: Trunk, Trusted
Link status last changed: 0d 00:00:00 ago
Last update of counters: 0d 00:00:00 ago
Last clearing of counters: 0d 00:00:00 ago
Statistics:
Received 0 frames, 0 octets
0 pps, 0 bps
0 unicast, 0 multicast, 0 broadcast
0 runts, 0 giants, 0 throttles
0 error octets, 0 CRC frames
Transmitted 0 frames, 0 octets
0 pps, 0 bps
0 throttles, 0 errors octets, 0 deferred
0 collisions, 0 late collisions
Interface is not PoE capable
What I find interesting is that Duplex and Speed are N/A, and Autoneg is off. However, this is the Ethernet profile that I created and applied in the GUI:
I have applied this same profile on a separate S3500, and the CLI reflected those changes accordingly.
I have tried different transceivers, different ports, different cables, and have restarted the switch twice. Is there something else I am missing? Is there a way to reset just the 4x10 module?
Thank you very much for your time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
