Campus Switching and Routing
Switch CoA Session-Context-Not-Found
I'm doing dot1x authentication and mac auth on a switch port and also trying to set users VLAN by using the RADIUS CoA. I'm getting the following message in the access tracker on clearpass and it's not setting the VLAN.
Application NamePolicy Manager
RADIUS CoA Action TypeCoA
RADIUS CoA Action NameChange to VLAN 251
Status Code0
Status MessageSession-Context-Not-Found
RADIUS CoA AttributesAruba-Vlan = 151
Calling-Station-Id = E8E0B7AC886B
Any tips?
Cheers
James
Aruba
Re: Switch CoA Session-Context-Not-Found
Check to make sure that the AAA profile for those ports has CPPM defined as the RFC 3576 server (with the same key as the Network Device definition).   Also, make sure Enable RADIUS CoA is enabled on the Network Device configuration for your switch.
AMFX | ACCX | ACDX | ACMX
Make sure you have CoA (rfc-3576-server) enabled in the AAA profile with the IP address(es) of your ClearPass server.
You can run the command show aaa rfc-3576-server statistics which will show the different types of CoA requests received/processed by the switch.
Tim Cappalli | Aruba Security
Thanks guys. Will check this in the lab tomorrow.
Cheers
James
Another thing to note is the controller-IP or the NAS IP set in the AAA advanced tab under Authentication in the controller.  Make sure that whatever the NAS IP is...that is matches on both ends for the CoA to work.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
I've added the RFC 3576 server to the aaa profile I'm using on the port.
Here's what the stats show :
It's working for 802.1x auth clients but not for the MAC auth clients.
Cheers
James
I just recreated my enforcement profile and it's working now.
Not 100% sure why though which is worrying. :smileyfrustrated:
Cheers
James
