Campus Switching and Routing
Frequent Contributor I
Switch
When you deploy a network what kind of switch you use, Cisco, D-Link, Brocade or something else?
Re: Switch
Aruba Mobility Access Switches
Tim Cappalli | Aruba Security
Re: Switch
Did you use Aruba Access Switche for a big network? I never user Aruba Mobility Access Swtiches it is a good products?
Re: Switch
Our entire campus uses them on the edge. We have 91 stacks totaling just over 325 switches.
Best edge switch we've ever had. We are able to apply the same policy to wired users as we do on the wireless with user-roles.
Also, it's hard to find a 48 port, gigabit, full POE switch with stacking and 10G uplinks for the price.
Re: Switch
Do you recommend this switch even if no Aruba access point is installed?
Re: Switch
Yes.
Re: Switch
Someone else to have an opinion?
Super Contributor II
Re: Switch
I would also vote for Aruba switches because of its profile base configuration. Although it is difficult to understand 1st time but once you are use to with it. You will be in ease.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Contributor I
Re: Switch
Usually, I use Aruba 2530 for access switch. Great feature, reasonable price and also limited lifetime warranty.
