Campus Switching and Routing
Tunneled-Node on a per VLAN basis
I cant see it possible to do Tunneled-Node on a per VLAN basis,
I wanted to have 802.1x on a port and if authentication failed or the port didn't receive an 802.1x auth packet, the VLAN would change and the connection is tunneled to the guest network on the controller.
I don't think its possible right now, is it, or is it on the roadmap?
Thank, AP
Re: Tunneled-Node on a per VLAN basis
Yes, just return a tunneled role. See the ClearPass Solution Guide for Wired Policy Enforcement.
Tim Cappalli | Aruba Security
