Campus Switching and Routing
VSF and Spanning-Tree (STP)
Hi all,
sry for my bad english.
I am planning to set up an 2x5406 VSF Core.
The Edge Switches (at this time not 100% sure) will bei 2540 or 2930F.
The Edge Switches will be connected with Trunks to the VSF, but for better redundancy i would like to interconnect some of the Edge Switches.
That leads me to the question:
-> Is it possible to run STP on the VSF Core?
-Alex
Re: VSF and Spanning-Tree (STP)
For sure you can still run STP on the virtual switch.
Ok, great.
Thanks!
