Campus Switching and Routing
WebGUI (https) access on 2930M with Radius Authentication
hi guys,
I'm currently struggling with an requisition of authentication some users via Radius to access a 2930M through https with only Read permissons (just like the operater user has)... the thing is that we're using a cisco acs for that and all tries to get it work failed so far :( maybe someone of you has expirience with this and could get me on track if this is possible at all?
thanks in advance
greets
Re: WebGUI (https) access on 2930M with Radius Authentication
The following video: https://www.youtube.com/watch?v=snNBFQi5l1Y may get you started. This is using ClearPass as the authentication server, however pointing to the relevant documentation, and if you return the same attributes, it should work.
