Campus Switching and Routing
Frequent Contributor II
Weird MAS PoE difficulties
I've had this problem on another S1500 switch, but can't for the life of me figure out why.
I have a WIFI Vlan and a default VLAN. For ports that I setup on the WIFI VLAN, I do not get POE delivered to the access point. These ports have the same POE profile. Despite this, a web gui dashboard interfaces show these as "disable" when nothing is connected, as opposed to "not drawing power"
If I move my AP connection from a 114 port to a default port, it lights up right away.
Here's my config:
#show conf
# Configuration file for ArubaOS
# ArubaOS Version 7.4.1.0 50853
version 7.4
enable secret "8eb7928301522873ebe6a40451664f14df48ef0bd08f47b5a8"
hostname "Security-Aruba"
clock timezone EST -5
location "Building1.floor1"
controller config 4
ip access-list eth validuserethacl
  permit any
netservice svc-dhcp udp 67 68
netservice svc-dns udp 53
netservice svc-ftp tcp 21
netservice svc-h323-tcp tcp 1720
netservice svc-h323-udp udp 1718 1719
netservice svc-http tcp 80
netservice svc-https tcp 443
netservice svc-icmp 1
netservice svc-kerberos udp 88
netservice svc-natt udp 4500
netservice svc-ntp udp 123
netservice svc-sip-tcp tcp 5060
netservice svc-sip-udp udp 5060
netservice svc-sips tcp 5061
netservice svc-smtp tcp 25
netservice svc-ssh tcp 22
netservice svc-telnet tcp 23
netservice svc-tftp udp 69
netservice svc-vocera udp 5002
ip access-list stateless allowall-stateless
  any any any  permit
ip access-list stateless cplogout-stateless
  user   alias controller sys-svc-https  dst-nat 8081
ip access-list stateless dhcp-acl-stateless
  any any svc-dhcp  permit
ip access-list stateless dns-acl-stateless
  any any svc-dns  permit
ip access-list stateless http-acl-stateless
  any any svc-http  permit
ip access-list stateless https-acl-stateless
  any any svc-https  permit
ip access-list stateless icmp-acl-stateless
  any any svc-icmp  permit
ip access-list stateless logon-control-stateless
  any any svc-natt  permit
ip access-list session validuser
  network 169.254.0.0 255.255.0.0 any any  deny
  any any any  permit
user-role authenticated
user-role denyall
user-role denydhcp
user-role guest
user-role logon
user-role preauth
crypto ipsec transform-set default-boc-bm-transform esp-3des esp-sha-hmac
crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
mgmt-user admin root a7cc8a63016987ecf339c58d2ab85f015b4cc57b9a2324c089
ntp server 10.110.138.1
firewall disable-stateful-h323-processing
ip domain lookup
aaa authentication mac "default"
aaa authentication dot1x "default"
aaa server-group "default"
 auth-server Internal
 set role condition role value-of
aaa profile "default"
aaa authentication captive-portal "default"
aaa authentication vpn "default"
aaa authentication mgmt
aaa authentication wired
web-server
aaa password-policy mgmt
traceoptions
probe-profile "default"
   protocol icmp
qos-profile "default"
policer-profile "default"
ip-profile
   default-gateway 10.110.138.1
   controller-ip vlan 110
mode-button
   enable factory-default
interface-profile ospf-profile "default"
   area 0.0.0.0
interface-profile pim-profile "default"
interface-profile igmp-profile "default"
stack-profile
ipv6-profile
activate-service-firmware
aruba-central
rogue-ap-containment
interface-profile switching-profile "default"
   access-vlan 110
interface-profile switching-profile "Upstream-profile"
   switchport-mode trunk
interface-profile switching-profile "WIFI-profile"
   access-vlan 114
interface-profile tunneled-node-profile "default"
interface-profile poe-profile "default"
interface-profile poe-profile "device-group-default"
   enable
   poe-priority high
interface-profile poe-profile "poe-factory-initial"
   enable
interface-profile enet-link-profile "default"
interface-profile lldp-profile "default"
interface-profile lldp-profile "lldp-factory-initial"
   lldp transmit
   lldp receive
   med enable
interface-profile mstp-profile "default"
interface-profile pvst-port-profile "default"
vlan-profile dhcp-snooping-profile "default"
vlan-profile mld-snooping-profile "default"
vlan-profile igmp-snooping-profile "default"
   snooping
vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
   snooping
spanning-tree
   mode mstp
gvrp
mstp
lacp
poe-management-profile slot "0"
vlan "1"
vlan "110"
vlan "111"
   description "Voice"
vlan "112"
   description "MultMedia"
vlan "113"
   description "Sodexo"
vlan "114"
   description "WIFI"
vlan "115"
   description "ServerPrinter"
interface gigabitethernet "0/0/0"
interface gigabitethernet "0/0/1"
interface gigabitethernet "0/0/2"
interface gigabitethernet "0/0/3"
interface gigabitethernet "0/0/4"
interface gigabitethernet "0/0/5"
interface gigabitethernet "0/0/6"
interface gigabitethernet "0/0/7"
interface gigabitethernet "0/0/8"
interface gigabitethernet "0/0/9"
interface gigabitethernet "0/0/10"
interface gigabitethernet "0/0/11"
interface gigabitethernet "0/1/0"
interface vlan "110"
   ip address 10.110.138.38 255.255.255.0
device-group ap
interface-group gigabitethernet "default"
   apply-to ALL
snmp-server community Zer0t0uchpr0visi0ning view ALL
snmp-server view ALL oid-tree iso included
snmp-server group ALLPRIV v1 read ALL notify ALL
snmp-server group ALLPRIV v2c read ALL notify ALL
snmp-server group ALLPRIV v3 noauth read ALL notify ALL
snmp-server group AUTHPRIV v3 priv read ALL notify ALL
snmp-server group AUTHNOPRIV v3 auth read ALL notify ALL
snmp-server group Zer0t0uchpr0visi0ning v1 read ALL
snmp-server group Zer0t0uchpr0visi0ning v2c read ALL
snmp-server enable trap
process monitor log
end
(Security-Aruba) #
Contributor II
Re: Weird MAS PoE difficulties
Kevets,
 On S1500-12P box, only 8 ports are PoE capable. Hence you might be seeing issue.
 You mentoned about '114 port to a default port'
 What is 114 port ?
-Vinay
Well I'll be damned (and highly irritated). Nowhere on the chassis does it indicate 8 powered ports or which ones. And the WebGUI has no complaint when you assign ports 8-11 to a powered profile.
So I'm assuming it's the first 8 ports (0-7) that get PoE?
What I meant by 114 is the VLAN assignment, which was the only difference I could see with the configuration of these ports.
Anyway, thanks for the help!
On all MAS switches, the ports that have an orange number are PoE capable. White numbers are not.
Sent from Nine
Tim Cappalli | Aruba Security
kevets,
Please see the installation guide here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/11520/Default.aspx
OK thanks. My bad for not reading the installation guide.
