How do you troulbleshoot user connectivity issues on Instant APs? On controllers we can perform user-debug. Is there anything similar on IAP? We have an issue that clients don't connect with the IAP. However, rebooting the IAP enables the client to connect with the SSID.
If you go to the support tab you could run these commands :
AP Log AP-Debug
AP Log User
AP Log All
And here's the list of troubleshooting commands you can run on the IAPs (But it also depends on the IAP OS version you have installed)
http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Troubleshooting.htm
