Question: Why APs don't come up after enabling Centralized Licensing?
Environment Information: Multi- Controller topology with Centralized Licensing enabled.
Symptoms: After enabling Centralized Licensing; APs won't come up and system log would have below message.
Sep 28 11:28:47 stm[31796]: <305036> <WARN> |stm| Adding the remote AP WAH-kxd2727 will push the AP limits over the platform limit.
Sep 28 11:28:47 stm[31796]: <305036> <WARN> |stm| Adding the remote AP WAH-LMJ0245 will push the AP limits over the platform limit.
Cause: The overall ap license limit is calculated as lowest of PEF, AP or RF Protect license. With Centralized-Licensing enabled; it's possible that one of the controller had a license which isn't present in other controller. As the licenses are shared; the overall license limits would become lowest of the three from centralized count.
Below is an example where Locals din't have RFProtect license but Master had. After enabling Centralized licensing; the overall AP capability is limited by the RFProtect license.
show ap license-usage
AP Licenses
Type Number
AP Licenses 81
RF Protect Licenses 2
PEF Licenses 81
Overall AP License Limit 2
AP Usage
Type Count
Active CAPs 21
Standby CAPs 0
RAPs 21
Remote-node APs 0
Tunneled nodes 0
Total APs 42
Remaining AP Capacity
Type Number
CAPs 0
RAPs 0
Resolution: To avoid the issue; it's ideal to have same set of licenses across all controller. If a license is installed but not in use; it can be removed by using "license del <key>" command.
