After a power outage, APs seem to come for a few seconds and APs are now continuously rebooting and not coming up on the Controller? What is one reason this can happen?
Environment  : Any Aruba Controller
Legacy Access Points - AP-61/65/70/8x
Aruba OS 5.0+
AP-70s are in a reboot cycle on the Controller.
The main cause is AP to Controller connectivity lost during power shutdown.  When the Controller and APs come back up, APs need to be re-approved.  If the connectivity remains intermittent, we may sometimes see the APs are struck in "certified-hold-switch-cert" state.  In such cases, APs will either recover automatically or if it takes too long for connectivity to be restored, it leaves the APs in this state until we manually approve the APs from the Controller.
We assume in this case that CPSec (Control-Plane Security) is enabled on the Controller.  The main cause is AP to Controller connectivity lost during power shutdown.  When the Controller and APs come back up, APs need to be re-approved.  If the connectivity remains intermittent, we may sometimes see the APs are struck in "certified-hold-switch-cert" state.  In such cases, APs will either recover automatically or if it takes too long for connectivity to be restored, it leaves the APs in this state until we manually approve the APs from the Controller.
To troubleshoot APs in a reboot cycle, logical troubleshooting follows as below:
1) Check the AP database for the actual status of the APs (Down/Rebooting etc.). and Flags to get a clue.
# show ap database
For this case, we noticed:
AP Database
Name         Group         AP Type  IP Address    Status    Flags Switch IP
Aruba-1   Aruba-group  65       192.168.1.24   Down              192.168.1.2
Aruba-2   Aruba-group  65       192.168.1.32   Down              192.168.1.2
Aruba-3   Aruba-group  65       192.168.1.23   Down              192.168.1.2
Aruba-4   Aruba-group  65       192.168.1.56   Rebooting  I      192.168.1.2
Aruba-5  Aruba-group  65       192.168.1.55   Rebooting  I      192.168.1.2
Aruba-6  Aruba-group  65       192.168.1.69   Rebooting  I      192.168.1.2
Aruba-7   Aruba-group  65       192.168.1.59   Rebooting  I      192.168.1.2
2) Verify whether the APs can build PAPI and GRE with the Controller.
# show datapath session table <AP IP>
For this case, we noticed for one AP:
 Source IP     Destination IP  Prot SPort DPort  Cntr Prio ToS Age    Destination TAge UsrIdx UsrVer Flags
192.168.1.24    192.168.1.2    47   0     0      0/0     0 0   0   1/2         3a16 1      1      F
192.168.1.2   192.168.1.24    47   0     0      0/0     0 0   0   1/2         31b8 1      1      F
3) Verify the system logs to check the reboot reason for APs.  A sample output that applies to our case:
(Aruba) #show log system 30
Jan 31 02:01:38 :311002:  <WARN> |AP Aruba-4@192.168.1.56 sapd|  Rebooting: SAPD: Unable to install cert. Need to re-approve AP
Jan 31 02:01:38 :303086:  <ERRS> |AP Aruba-4@192.168.1.56 nanny| Process Manager (nanny) shutting down - AP will reboot!
Jan 31 02:01:38 :311002:  <WARN> |AP Aruba-7@192.168.1.59 sapd|  Rebooting: SAPD: Unable to install cert. Need to re-approve AP
Jan 31 02:01:38 :311002:  <WARN> |AP Aruba-6@192.168.1.69 sapd|  Rebooting: SAPD: Unable to install cert. Need to re-approve AP
Jan 31 02:01:39 :303086:  <ERRS> |AP Aruba-6@192.168.1.69 nanny| Process Manager (nanny) shutting down - AP will reboot!
Jan 31 02:01:39 :303086:  <ERRS> |AP Aruba-7@192.168.1.59 nanny| Process Manager (nanny) shutting down - AP will reboot!
4) Verify the CAP Whitelist to check the CPSec status of the APs:
(Aruba) #show whitelist-db cpsec
Control-Plane Security Whitelist-entry Details
MAC-Address        Enable   State                       Cert-Type    Description  Revoke Text  Last Updated
00:0b:86:c7:6e:32  Enabled  certified-hold-switch-cert  switch-cert                            Thu Jan 31 02:03:01 2013
00:0b:86:c7:6d:56  Enabled  certified-hold-switch-cert  switch-cert                            Thu Jan 31 02:03:01 2013
00:0b:86:c7:6f:26  Enabled  certified-hold-switch-cert  switch-cert                            Thu Jan 31 02:03:05 2013
00:0b:86:c7:6d:3e  Enabled  certified-hold-switch-cert  switch-cert                            Thu Jan 31 02:03:05 2013
The resolution is to manually approve the APs from Configuration > Wireless> AP Installation> Campus Whitelist> Select the AP MAC address - Modify - Select "approved-ready-for-cert".  We will see the AP reboots and comes up fine after manually approving:
(Aruba) #show ap database long | include 31.45
Aruba-4          Aruba-group   65       192.168.1.56   Generating CSR  I      192.168.1.2  00:0b:86:c7:6e:32  A62203877  1/10       57\.2\.2417.Floor 1.Aruba-group.Main Campus   N/A
Aruba-4          Aruba-group   65       192.168.1.56   Installing cert  I      192.168.1.2  00:0b:86:c7:6e:32  A62203877  1/10       57\.2\.2417.Floor 1.Aruba-group.Main Campus   N/A
Aruba-4          Aruba-group   65       192.168.1.56   Rebooting  I      192.168.1.2  00:0b:86:c7:6e:32  A62203877  1/10       57\.2\.2417.Floor 1.Aruba-group.Main Campus   N/A
Aruba-4          Aruba-group   65       192.168.1.56   Up 1m:1s   2      192.168.1.2  00:0b:86:c7:6e:32  A62203877  1/10       57\.2\.2417.Floor 1.Aruba-group.Main Campus   N/A
(Aruba) #show ap active
Active AP Table
Name       Group   IP Address   11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime  Outer IP
Aruba-4  Aruba-group  192.168.1.56  0            AP:6/9/20.5          0            AP:165/15/21         65       A2a    1m:8s   N/A
# show ap database
AP Database
Active AP Table
Version history
Revision #:
1 of 1
Last update:
‎07-18-2014 10:48 AM
Updated by:
Labels (1)
Contributors
