Controller Based WLANs
last person joined: one year ago
APs, Controllers, VIA
Authorization and Access for AP-Provisioning
Apr 01, 2017 01:24 AM
WLAN administrator to facilitate only AP provisioning access for the users logging on to the Controller.
Starting Aruba OS 8.0, WLAN administrator can provide AP provisioning level access for the users logging into the Controllers. With the provisioning level log on access, users would be able to provision the access points as needed as well as execute AP related commands that are useful to view the output and troubleshoot during the time of provisioning.
Following are the show commands supported for AP-Provisioning level of access.
  • show ap provisioning …
    show whitelist-db cpsec/rap …
    show ap database …
    show ap radio-database …
    show ap config …
    show ap details…
    show ap port status ..
    show ap allowed-channels …
    show ap ap-group …
    show ap image version
Following are the commands that can be executed when logged using AP-Provisioning level of access.
  • whitelist-db  cpsec/rap  add/delete/modify/revoke/purge …
    write memory
    read-bootinfo …
    reprovision …
    copy-provisioning-params …
    clear provisioning-ap-list
    provision-ap … (all sub-mode action commands)
    apflash …
    apboot
    ap-regroup
    ap-rename
Web UI Configuration:
Navigate to Configuration > System > Admin > Click on the add button under Management Users
CLI Configuration:
(Mobility-MM) [mynode] (config) #mgmt-user Test
<rolename>              Role name from one of the following:
root - super user role
guest-provisioning - guest provisioning role
network-operations - Network operator role
read-only - Read only role
location-api-mgmt - Location API Management Role
nbapi-mgmt - NBAPI Management Role
ap-provisioning - ap provisioning role
(Mobility-MM) [mynode] (config) #mgmt-user Test ap-provisioning
Password:*******
Re-Type Password:*******
(Mobility-MM) ^[mynode] (config) #
(Mobility-MM) ^[mynode] (config) #write memory
Saving Configuration...
Partial configuration for /mm/mynode
Contents of : /flash/config/partial/7/p=sc=mynode.cfg
mgmt-user Test ap-provisioning 30e155df01d57ad96fc6ef4282089c95bce4e52677382bedd8
Configuration Saved.
Executing "show mgmt-user" will help confirm the creation of user account and their level of access under the index "ROLE", as shown below
(Mobility-MM) [mynode] (config) #show mgmt-user
Management User Table
USER    PASSWD  ROLE              STATUS   PATH
Test    *****   ap-provisioning   ACTIVE   /
admin   *****   root              ACTIVE   /
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
