Q:
Port bounce feature on controller.
Support for Port bounce has been introduced in 8.2.x version. With this feature, the ports can be shutdown for upto 60 seconds (max) and wired clients can be forced to reconnect/reauthenticate. This can also be used to change the VLAN of the client by sending a CoA.
CoA (Change of Authorization) can be sent by any RADIUS server such as CPPM using the Aruba VSA: Aruba-Host-Port-Bounce. The Disconnect Request contains the client mac address in the calling-stattion-id and can specify time for which the port has to be in shutdown state. Max value is 60 seconds.
If the value is specified as '0', the port is not shutdown.
(A7030_cluster1) #show port status Port Status ----------- Slot-Port PortType AdminState OperState PoE Trusted SpanningTree PortMode Speed Duplex PortError --------- -------- ---------- --------- --- ------- ------------ -------- ----- ------ --------- 0/0/0 GE Enabled Up N/A Yes Forwarding Access 1 Gbps Full - 0/0/1 GE Enabled Up N/A N/A Forwarding Access 1 Gbps Full - 0/0/2 GE Enabled Down N/A No Disabled Access Auto Auto Port Bounce (CoA)
(Master) #show log security 10 | include aaa Dec 4 11:19:09 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_sequence.c:117] seq_num_timeout_handler: Freed 0 entries Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_rfc3576.c:189] Received rfc-3576 request (code:40) from 10.17.168.99:42933 Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_rfc3576.c:193] Aruba-Port-Bounce-Host: 60 Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_rfc3576.c:193] Calling-Station-Id: A08CFDA32DF8 Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_api.c:1316] User is wired, setting nas_port_type to wired, port to 8450 Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [user.c:13855] Received VSA Vendor-Specific: 26 Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_server.c:2558] Sending radius response to 10.17.168.99:42933 Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_server.c:2563] NAS-IP-Address: 10.7.44.72 Dec 4 11:19:17 :121031: <3949> <DBUG> |authmgr| |aaa| [rc_server.c:2563] NAS-Port-Type: Ethernet
