Q:
What are the different ways in which wireless tunnel mode user entry ages out of the controller ?
Wireless tunnel mode user can age out in one the following ways :
1. Client sends dis-association to the AP.
Client will age out after user idle timeout configured on the controller.
2. Client loses power (remove the battery) or walks away without sending dis-association.
A tunnel mode client that drops off without sending a deauth will be subjected to a timeout of:
Maximum ( STA ageout, user-idle timeout )
if sta ageout is 1000, and user-idle is 30, then the effective timeout is 1000.
If sta ageout is 100, and the user-idle is 300, then the effective timeout is 300.
3. AP reboot.
