Controller Based WLANs
last person joined: one year ago
APs, Controllers, VIA
How do I make stateful dot1x work in the ArubaOS 3.x code?
Jul 01, 2014 05:45 PM
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.0 and later.
Stateful dot1x is the authentication type that allows the Aruba controller to apply firewall rules to the wireless users that are associated with non-Aruba APs and are doing dot1x authentication.
Configuration
To make stateful dot1x work in ArubaOS 3.x code:
•     The physical port of the controller, which is the ingress port of the third-party APs' traffic, needs to be configured as an "untrusted" port.
•     Wired authentication is not mandatory for stateful dot1x authentication. However, if "aaa authentication wired" is enabled, the "initial role" of the aaa profile applied to wired authentication as "logon" role must be configured for stateful dot1x to work. Any other name of initial role breaks stateful dot1x. When stateful dot1x authentication is enabled and a RADUIS-server group has been applied to "stateful-dot1x" profile, the controller automatically generates the "stateful-dot1x" ACL and applies it to the end of the user-role "logon" as shown in this sample configuration:
user-role logon
session-acl logon-control
session-acl captiveportal
session-acl vpnlogon
session-acl stateful-dot1x   ====>automatically added
aaa server-group "test-server-group"
auth-server test
aaa authentication-server radius "test"
   host 10.168.1.1
   key 80ecd0c91e076c92e94ecdf51cd5b5aa
   authport 1812
   acctport 1813
aaa authentication stateful-dot1x
           enable
           default-role authenticated
           server-group test-server-group
# show ip access-list stateful-dot1x
1 any     any          svc-dns   permit
2 any     any          svc-dhcp  permit
3 any     10.168.1.1  udp 1812  redirect opcode 52
•     Make sure the dot1x authentication traffic is going through the controller, otherwise the controller will not be able to monitor the authentication transaction and apply the right user role to the user when the authentication process is finished.
Troubleshooting
1)  logging level debug security process authmgr
2)  show acl hits role logon
"show log security" in a working case:
Oct 17 14:09:37 :124004:  <DBUG> |authmgr|  Forwarding the Radius packet after
stateful dot1x processing code:1/smac:00:0d:bd:bb:d2:a3/sport:1645/dport:1812
Oct 17 14:09:37 :124004:  <DBUG> |authmgr|  Received Valid Radius Reponse
Oct 17 14:09:37 :124007:  <INFO> |authmgr|  USER_NAME
Oct 17 14:09:37 :124007:  <INFO> |authmgr|  EAP MESSAGE
Oct 17 14:09:37 :124004:  <DBUG> |authmgr|   {L2} Authenticating Server is test
Oct 17 14:09:37 :199802:  <ERRS> |authmgr|  user.c, derive_role2:3707:
{00:1d:e0:12:f4:a1-0.0.0.0} Missing server group in attribute list,
auth=Stateful-802.1x, utype=L2
Oct 17 14:09:37 :124004:  <DBUG> |authmgr|  Tx message to Sibyte. Opcode = 17,
msglen = 132
Oct 17 14:09:37 :124007:  <INFO> |authmgr|  Forwarding the Radius Response to
AP:192.168.1.100 len:0
stateful dot1x processing code:2/smac:00:0b:86:40:3a:60/sport:1812/dport:1645
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
