Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
You can restore the controller to factory default from the CLI or from the WebUI.
From CLI
write erase
or
write erase all
Then reload the controller.
From WebUI
Maintenance > Switch - clear configuration
(This is equivalent to the 'write erase' command.)
The 'write erase' command only restores the configuration saved on flash to the factory default configuration and changes the boot configuration file to the 'default.cfg' file.
The 'write erase all' command erases:
