Environment : This applies to all AOS versions above 3.4.x
Before we try to understand how much bandwidth will be consumed by RTLS packets we need to understand what is "Update Interval" and how it works.Update Interval:*****************(Aruba3400) #show ap monitor debug status ap-name 125RTLS Configuration and State-----------------------------Type Server IP Port Freq Active Rpt-Tags Tag-Mcast-Addr Tags-Sent Rpt-Sta Incl-Unassoc-Sta Sta-Sent Cmpd-Msgs-Sent CM---- --------- ---- ---- ------ -------- -------------- --------- ------- ---------------- -------- -------------- --MMS N/A N/A 30 disable 01:0c:cc:00:00:00 N/A disable N/A N/A N/A N/AAeroscout N/A N/A N/A disable 00:00:00:00:00:00 N/A disable N/A N/A N/A N/ARTLS 1.1.1.1 1234 30 disable 01:18:8e:00:00:00 N/A disable N/A N/A N/A enableThe update interval sets how often updated information for a single device will be sent in the RTLS data stream. If it is set to 30 seconds, rtls data for a specific client will be sent every 30 seconds. So if there 30 clients, there will be an update roughly every second that includes a single clients data. Now if there are 90 clients heard, there will still be an update every second but it will include data for 3 clients. If there are only 10 clients, there will be some seconds where no updates are sent. There will be 10 updates in that 30 seconds.Now we know how update interval works, we have the below formulae to calculate the approximate bandwidth requirement per second:
header size: 16 bytessignature size: 20 bytesclient data size: 28 bytesThe requirement changes based on the "update interval" set and the "number of clients" connected to the AP.If we assume there are 90 clients being heard, then the average Bps will be (16)+(20)+(1/30)(90)(28) = 120 Bytes per second for a single AP.
