All Aruba OS.
This command checks AP antenna connectivity. The Signal to Noise Ratio (SNR) of the entire antenna in that ApUse the following command from the CLI of the controller===============================================(qvslgwfarc01) #rft test profile antenna-connectivity ip-addr 10.44.53.249 dest-mac 00:26:08:a0:d7:99 phy gTransaction ID: 4201Ip address: Ap’s ip addressDest-Mac: client’s mac address Use the following command to get the test results.==========================================(qvslgwfarc01) #show rft result trans-id 4201Profile AntennaConnectivity, TransID 4201, AP 10.44.53.249, Dest 00:26:08:a0:d7:99, Radio 1--------------------------------------------------------------------------------------------Antenna Connectivity Test Result--------------------------------Antenna 1: Avg S/N ratio: 45 Success Rate: 50%Antenna 2: Avg S/N ratio: 48 Success Rate: 8%Difference: 3 42% Destination went into power-save during the test. Results may not beaccurate. For accurate results, disable power-save on the destination.
