Introduction : Master-Local setup build the IPSec tunnel to exchange the control messages. By default is uses IKEv1 and aggressive mode as the first exchange. However, we can configure the Master-Local to build the IPSec tunnel using IKEv2, for which they use inbuilt certificates.
Network Topology :
Configuration Steps :
Master Controller configuration
- Define the Local controller MAC address
(config) #local-factory-cert local-mac <MAC address of the local controller, can be seen under command #show switchinfo )
Local controller Configuration
- Define the Master controller MAC address
(config) #masterip 172.16.0.254 ipsec-factory-cert master-mac-1 < MAC address of the Master controller, can be seen under command #show switchinfo )
Answer :
Master-Local setup build the IPSec tunnel to exchange the control messages. By default is uses IKEv1 and aggressive mode as the first exchange. However, we can configure the Master-Local to build the IPSec tunnel using IKEv2, for which they use inbuilt certificates.Using above configuration we can setup the IPSec tunnel using IKEv2
Verification :
We can confirm the IPSec is set using IKEv2 by below commands
Local
(Local) #show roleinfo
switchrole:local
masterip:172.16.0.254
Certificate Type: Factory Certificates
Master MAC: 00:0b:86:6e:a2:34
(Local) #show switches
All Switches
IP Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
172.16.0.252 Local Building1.floor1 local Aruba3400 6.3.1.3_42233 up UPDATE SUCCESSFUL 0 2
(Local) #show crypto ipsec sa
IPSEC SA (V2) Active Session Information
Initiator IP Responder IP SPI(IN/OUT) Flags Start Time Inner IP
172.16.0.252 172.16.0.254 d5425500/8d768400 UT2 Mar 27 15:03:53 -
Flags: T = Tunnel Mode; E = Transport Mode; U = UDP Encap
L = L2TP Tunnel; N = Nortel Client; C = Client; 2 = IKEv2
Total IPSEC SAs: 1
Master
(Master) #show roleinfo
switchrole:master
(Master) #show switches
All Switches
172.16.0.254 Master Building1.floor1 master Aruba3600 6.3.1.3_42233 up UPDATE SUCCESSFUL 0 2
172.16.0.252 Local Building1.floor1 local Aruba3400 6.3.1.3_42233 up UPDATE SUCCESSFUL 8 2
(Master) #show crypto ipsec sa
172.16.0.252 172.16.0.254 8d768400/d5425500 UT2 Mar 27 10:41:24 -
