How to control number of eap-ip-req sent to a client ?
MVP
MVP
Q:
A:
In AOS, while doing 802.1x authentication there would be scenarios where we need to control the number of eap-id-requests sent to  the client.
Example of a scenario would be where 802.1x-TLS is performed and client takes time to accept the certificate presented by the Server(termination on external auth server).
By default 15 eap-id-requests are sent.  Using the below knobs the count can be changed as desired:
"Reauth-Max" * "Max-Requests"  is the max number of eap-id-req be sent.  Default 3 * 5 = 15
3 = Reauth-Max ==> Number of times the same id-req will be sent.
5 = Max-Requests ==> The total number of EAP requests which the controller will send out for a single EAP transaction
Sep 28 19:14:16  eap-start             ->  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                -   -
Sep 28 19:14:16  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                1   5    ==> eap-id-req ----> seq1
Sep 28 19:14:21  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                1   5    ==> eap-id-req ----> seq1
Sep 28 19:14:26  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                1   5    ==> eap-id-req ----> seq1
Sep 28 19:14:31  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                2   5    ==> eap-id-req ----> seq2
Sep 28 19:14:36  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                2   5    ==> eap-id-req ----> seq2
Sep 28 19:14:41  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                2   5    ==> eap-id-req ----> seq2
Sep 28 19:14:46  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                3   5
Sep 28 19:14:51  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                3   5
Sep 28 19:14:56  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                3   5
Sep 28 19:15:01  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                4   5
Sep 28 19:15:06  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                4   5
Sep 28 19:15:11  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                4   5
Sep 28 19:15:16  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                5   5
Sep 28 19:15:21  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                5   5
Sep 28 19:15:26  eap-id-req            <-  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                5   5
Sep 28 19:15:31  station-down           *  fc:f8:ae:51:4b:7c  94:b4:0f:10:53:d4                -   -
The interval between the eap-id-req is 5 seconds by default. "timer idrequest_period" is knob used to tweak this value.
Below is a sample auth-tracebuf output with all the above mentioned values modified:
(master) #show aaa authentication dot1x "akhil-.1x" | include Max,Req
Interval between Identity Requests                                          7 sec
Max number of requests sent during an Auth attempt        2
Max Number of Reauthentication Attempts                           2
Nov 25 10:29:27  eap-start             ->  3c:a9:f4:7f:84:54  18:64:72:ed:62:a0  -  -
Nov 25 10:29:27  eap-id-req            <-  3c:a9:f4:7f:84:54  18:64:72:ed:62:a0  1  5
Nov 25 10:29:34  eap-id-req            <-  3c:a9:f4:7f:84:54  18:64:72:ed:62:a0  1  5
Nov 25 10:29:41  eap-id-req            <-  3c:a9:f4:7f:84:54  18:64:72:ed:62:a0  2  5
Nov 25 10:29:48  eap-id-req            <-  3c:a9:f4:7f:84:54  18:64:72:ed:62:a0  2  5
Nov 25 10:29:55  station-down           *  3c:a9:f4:7f:84:54  18:64:72:ed:62:a0  -  -
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:12 PM
Updated by:
Labels (1)
Contributors
