Environment This applies to all controller model and AOS versions.
In controller we do have an option to disable "audit-trail".Below is the command to disable the same.(Aruba3400) (config) #interface gigabitethernet 1/0 no trusted(Aruba3400) (config) #write memorySaving Configuration...Configuration Saved.(Aruba3400) (config) #show audit-trail 5Aug 15 13:42:26 cli[1507]: USER:admin@10.20.25.33 COMMAND:<interface gigabitethernet "1/0" no trusted > -- command executed successfullyAug 15 13:42:30 cli[1507]: USER:admin@10.20.25.33 COMMAND:<write memory > -- command executed successfully(Aruba3400) (config) #no audit-trail ====> This will disable audit-trail(Aruba3400) (config) #write memorySaving Configuration...Configuration Saved.(Aruba3400) (config) #interface gigabitethernet 1/0 trusted(Aruba3400) (config) #write memorySaving Configuration...Configuration Saved.(Aruba3400) (config) #show audit-trail 5Aug 15 13:42:26 cli[1507]: USER:admin@10.20.25.33 COMMAND:<interface gigabitethernet "1/0" no trusted > -- command executed successfullyAug 15 13:42:30 cli[1507]: USER:admin@10.20.25.33 COMMAND:<write memory > -- command executed successfully(Aruba3400) (config) #audit-trail ====> This will enable audit-trail(Aruba3400) (config) #write memorySaving Configuration...Configuration Saved.(Aruba3400) (config) #interface gigabitethernet 1/0 no trusted(Aruba3400) (config) #write memorySaving Configuration...Configuration Saved.(Aruba3400) (config) #show audit-trail 10Aug 15 13:42:26 cli[1507]: USER:admin@10.20.25.33 COMMAND:<interface gigabitethernet "1/0" no trusted > -- command executed successfullyAug 15 13:42:30 cli[1507]: USER:admin@10.20.25.33 COMMAND:<write memory > -- command executed successfullyAug 15 13:43:33 cli[1507]: USER:admin@10.20.25.33 COMMAND:<interface gigabitethernet "1/0" no trusted > -- command executed successfullyAug 15 13:43:36 cli[1507]: USER:admin@10.20.25.33 COMMAND:<write memory > -- command executed successfully
