How to fix perf-test report connection timed out for tcp?
Question: How to fix perf-test report connection timed out for tcp?
Environment: Only AP-130 Series, AP-220 Series, and AP-105 access points connected to a 7200 Series or M3 controller running AOS 6.3 and above support this feature.
Below are the steps to run perf-test for tcp when controller runs as perf-test server and AP as client.
(Aruba) (config) # perf-test server start controller tcp window 256k
NOTE:Please make sure that CP whitelist was configured, permit TCP packets to forward. (TCP portocol number 6, perf-test port 5001)
     If you have done, please ignore this prompt
NOTE:Need to execute 'perf-test port open' because cpsec is enabled
(Aruba) #perf-test port open
(Aruba) #perf-test client start ap ap-name ArubaAP host 172.16.0.254 tcp window 256k duration 10
(Aruba) #show perf-test reports controller
Command Warning:No perf-test reports on this Controller
In the datapath session table, we could see 'D' flag for the tcp port 5001.
(Aruba) # show datapath session table 192.168.0.13  | include 5001
192.168.0.13    172.16.0.254    6    63094 5001   0/0     0 0   0   tunnel 13   5    0         0          FDYC
 When show perf-test reports is executed the connection times out.
(Aruba) #show perf-test reports ap ap-name ArubaAP
Perf-test: Success
 Jul  3 16:12:15 2014
connect failed: Connection timed out
In order the reolve the connection timed out issue, we need add an firewall cp acl to allow tcp port 5001 as shown below:
(Aruba) (config) #firewall cp
(Aruba) (config-fw-cp) #ipv4 permit any proto 6 ports 5001 5001
After allowing tcp 5001, we could see perf-test reports successfully for tcp.
(Aruba)#show perf-test reports ap ap-name ArubaAP
Perf-test: Success
Jul 22 14:42:05 2014
Client connecting to 100.0.0.1, TCP port 5001
TCP window size:  260 KByte (WARNING: requested  256 KByte)
[  3] local 120.0.0.254 port 57435 connected with 100.0.0.1 port 5001
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0- 1.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  1.0- 2.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  2.0- 3.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  3.0- 4.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  4.0- 5.0 sec  11.0 MBytes  92.3 Mbits/sec
[  3]  5.0- 6.0 sec  11.0 MBytes  92.3 Mbits/sec
[  3]  6.0- 7.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  7.0- 8.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  8.0- 9.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  9.0-10.0 sec  11.1 MBytes  93.3 Mbits/sec
[  3]  0.0-10.0 sec   111 MBytes  93.1 Mbits/sec
 Note: Adding firewall cp acl is applicable only for tcp and not for udp.
Version history
Revision #:
1 of 1
Last update:
‎08-14-2014 04:09 PM
Labels (1)
Contributors
