There could be a requirement wherein we need to connect a mesh point to a particular mesh portal amongst multiple mesh portal in the same mesh cluster.
We can use "apconnect" command to instruct the mesh-point to connect to a new parent.
(Aruba) #ap? apconnect Instruct Mesh-Point to connect new parent
(Aruba) #show ap mesh active Mesh Cluster Name: mesh-test ------------------------------- Name Group IP Address BSSID Band/Ch/EIRP/MaxEIRP MTU Enet 0/1 Mesh Role Parent #Children AP Type Uptime ---- ----- ---------- ----- -------------------- --- -------- --------- ------ --------- ------- ------ Point mesh 10.10.50.249 00:1a:1e:93:93:00 802.11a/36+/15/21 Off/Off Point Portal 0 121 21m:54s Portal mesh 10.10.50.251 00:1a:1e:87:e6:10 802.11a/36+/20/21 1500 -/Off Portal - 1 125 23m:14s Portal-2 mesh 10.10.50.253 00:1a:1e:8f:af:10 802.11a/36+/20/21 1500 -/Off Portal - 0 125 23m:7s (Aruba) #apconnect ap-name Point parent-bssid 00:1a:1e:8f:af:10
(Aruba) #show ap mesh active Mesh Cluster Name: mesh-test ------------------------------- Name Group IP Address BSSID Band/Ch/EIRP/MaxEIRP MTU Enet 0/1 Mesh Role Parent #Children AP Type Uptime ---- ----- ---------- ----- -------------------- --- -------- --------- ------ --------- ------- ------ Point mesh 10.10.50.249 00:1a:1e:93:93:00 802.11a/36+/15/21 Off/Off Point Portal-2 0 121 26m:11s Portal mesh 10.10.50.251 00:1a:1e:87:e6:10 802.11a/36+/20/21 1500 -/Off Portal - 0 125 27m:31s Portal-2 mesh 10.10.50.253 00:1a:1e:8f:af:10 802.11a/36+/20/21 1500 -/Off Portal - 1 125 27m:24s
Now the Mesh point named "Point" is connected to the Portal-2". Earlier it was on Mesh Portal named "Portal".
