Q: Why does the locate tab not function post upgrade to 6.4.3.x ?
A: On the webUI, navigate to Dashboard --> Security --> Discovered APs and Clients. If we click on either rogue AP, suspected rogue or interfering APs and select one of the BSSID followed by clicking on locate button. A pop up window appears and displays "no matches found". This is only noticed after upgrading to 6.4.3.x and prior to this all versions would display the access point which has located the device.
In 6.4.3 WMS, we have disabled the writing of location data to the database. It is disabled by default, and can be enabled by toggling the stat-update parameter in the IDS WMS General profile.
show ids wms-general-profile
IDS WMS General Profile
Parameter Value
AP poll interval 60000 msec
AP poll retries 2
AP ageout interval 30 minutes
Adhoc AP ageout interval 5 minutes
Station ageout interval 30 minutes
Statistics update false
Persistent Neighbor APs true
Persistent Valid STAs false
AP learning false
Propagate Wired Macs true
Collect Stats for Monitored APs and Clients false
Learn System Wired Macs false
To enable via CLI, please execute the below command-
(Aruba) (config) #ids wms-general-profile
(Aruba) (IDS WMS General Profile) #stat-update
To verify, execute the below command-
Parameter Value
AP poll retries 2
Statistics update true
AP learning false
Attachments:Locate Discovered APs.PNG
