What are the set of threshold values and how to configure them?
These threshold values will send alert when the Aruba Controller is loaded excessively.
We can configure the threshold values for below parameters so that when the controller reaches the configured threshold value it will send an SNMP trap message to the SNMP receiver.
  • controlpath-cpu
  • controlpath-memory
  • datapath-cpu
  • no-of-APs
  • no-of-locals
  • total-tunnel-capacity
  • user-capacity
Below are the sample configuration to set the threshold values.
(ArubaMaster) #
(ArubaMaster) #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(ArubaMaster) (config) #threshold no-of-locals 70
(ArubaMaster) (config) #threshold no-of-aPs 70
(ArubaMaster) (config) #exit
(ArubaMaster) #
We can verify the configured threshold values using below command.
(ArubaMaster) #show threshold all
Capacity Threshold Values
RESOURCE            THRESHOLD(%)
Datapath CPU        30 %
Controlpath CPU     45 %
Controlpath Memory  85 %
Total Tunnels       80 %
Total Users         80 %
Total APs           70 %
Total Locals        70 %
(ArubaMaster) #
We can verify the default values by executing below command for specific parameter.
(ArubaMaster) #show threshold-limits user-capacity
Threshold Values For No of Users
Default(%)  Current(%)  MAX Users  Current Users
80          80          16384      0
(ArubaMaster) #show threshold-limits no-of-locals
Threshold Values For No Of Locals
Default(%)  Current(%)  Max Locals   No of Locals connected
80          70          256          2
(ArubaMaster) #
Version history
Revision #:
2 of 2
Last update:
3 weeks ago
Updated by:
Labels (1)
Contributors
