Environment- It is applicable to controllers running 6.x version
Answer- Its the “RF" distance between two Aps (in dB). Measured by Aps when they hear OTA updates from other Aruba Aps which has tx power of the sending AP. Receiving AP will calculate path loss based on measured received signal for the known tx power. Higher the number, farther the APsshow ap arm neighbors command:ARM Neighbors-------------bssid essid channel rssi tx-power PL (dB) AP Flags Last Update ----- ----- ------- ---- -------- ------- -------- ------------6c:f3:7f:45:57:20 7SPOT 1 8 0 0 Passive6c:f3:7f:56:7e:a0 7SPOT 1 9 0 0 Passive6c:f3:7f:56:7e:a1 NTT-SPOT 1 12 0 0 Passive00:24:6c:80:77:c1 NTT-SPOT 1 9 0 0 Passive6c:f3:7f:45:57:21 NTT-SPOT 1 8 0 0 Passive6c:f3:7f:44:91:11 NTT-SPOT 1 9 0 0 Passive00:24:6c:2b:fd:e8 qa-mv-vap3 161 5 9 98 Passive00:24:6c:80:4d:62 docomo 1 10 0 0 Passive
