Product and Software: This article applies to ArubaOS 3.2.x and later.
By default, the transmit power for mesh nodes is set to maximum, which is 30 dBm. This default is different from the default transmit power for virtual AP, which is 15 dBm.
If you have two mesh APs in a very short distance, you may want to reduce the transmit power so that the RF receiver on its mesh peer is not saturated. You can change the transmit power in mesh-radio-profile.
#show ap mesh-radio-profile default
Mesh Radio profile "default"
Parameter Value
Maximum Children 64
Maximum Hop Count 8
Heartbeat threshold 10
Link Threshold 12
Reselection mode startup-subthreshold
Metric algorithm distributed-tree-rssi
802.11g Portal channel N/A
802.11a Portal channel N/A
Beacon Period 100 msec
Transmit Power 30 dBm
Retry Limit 4
RTS Threshold 2333 bytes
802.11a Transmit Rates 6 9 12 18 24 36 48 54
802.11g Transmit Rates 1 2 5 6 9 11 12 18 24 36 48 54
Mesh Private Vlan 0
BC/MC Rate Optimization Enabled
