Environment- 11ac Mesh troubleshooting in 6.4.3
Answer- Logs in the below format will be seen when a 11ac Mesh Point begins to scan Neighborhood.[904]1969-12-31 16:00:26.118 meshd_scan_init: meshd_getchan_regtlb() gave 22 chans, mcc:0, ccode:67, cname:"US" band:1[904]1969-12-31 16:00:26.119 meshd_binary_wif_sysctl: programmed /proc/sys/dev/wifi0/mesh_cmn_struct[904]1969-12-31 16:00:26.119 meshd_scan_all_channels: num_scan_channels: 22, scan_ch_index: 1, start-tick: 0. Scanning...[904]1969-12-31 16:00:26.119 meshd_set_rssi_threshold: thresh: 12, delta: 1, max_rssi: 38[904]1969-12-31 16:00:26.622 meshd_binary_wif_sysctl: programmed /proc/sys/dev/wifi0/mesh_cmn_struct[904]1969-12-31 16:00:26.622 meshd_init_ht_conf: HT=1 Band=a HT_CAP: 40MHz_allow=1 ext_off=0 sgi=1 mx_rx_mpdu=65535 mcs=0-15 chan=36, intol:0, legacy: 0[904]1969-12-31 16:00:26.622 meshd_init_ht_conf:1571 vht_cap 0x2 with mpdu size 0x2[904]1969-12-31 16:00:26.622 meshd_init_ht_conf:1587 vht_cap 0x2 with bandwidth type 80m[904]1969-12-31 16:00:26.622 meshd_init_ht_conf:1594 vht_cap 0x12 with LDPC 0x10[904]1969-12-31 16:00:26.622 meshd_init_ht_conf:1614 vht_cap 0x32 with SIG_80 0x20[904]1969-12-31 16:00:26.623 meshd_init_ht_conf:1621 vht_cap 0x832 with SU_BEAMFMR 0x800[904]1969-12-31 16:00:26.623 meshd_init_ht_conf:1624 vht_cap 0x1832 with SU_BEAMFMEE 0x1000[904]1969-12-31 16:00:26.623 meshd_init_ht_conf:1653 vht_op supp_mcs 0xffea, vht_op_ch_freq_seg1 36[904]1969-12-31 16:00:26.623 meshd_set_mvap_ht_props: ht->supported_mcs_set.bits: ffff0000[904]1969-12-31 16:00:26.632 meshd_set_mvap_ht_props: Set VAP commit on node: /proc/sys/net/aruba000/commit[904]1969-12-31 16:00:26.633 meshd_set_mvap_ht_props: ht->supported_mcs_set.bits: ffff0000[904]1969-12-31 16:00:26.636 meshd_set_mvap_ht_props: Set VAP commit on node: /proc/sys/net/aruba001/commit[904]1969-12-31 16:00:26.636 Bringing up mesh_c VAP 0:0 ((flags:0x1002)[904]1969-12-31 16:00:38.704 scan-summary: 36:s 40:s 44:s 48:s 52:s 56:s 60:s 64:s 100:s 104:s 108:s 112:s 116:s 132:s 136:s 140:s 144:s 149:s 153:s 157:s 161:0 165:0 scan-key: n:not-set,i:invalid,b:blacklisted,s:set,<number>:probe-resp-cnt.
