Controller Based WLANs
Why do we need “alias” or “netdestination” and how to configure it on Aruba controller?
This article explains the use of “netdestination” or “alias” and steps to configure it on the Aruba controller
“Alias” or “Netdestination” is created as an alias to a specific host, network or to club together a set of hosts/networks. While using this option, you need to configure the IP address of the host/network.
This can be useful if we need to allow/disallow a specific set of hosts/network then we need not permit or deny each host/network separately. We can instead create a netdestination containing those hosts/networks and allow or disallow access.
Environment : This article applies to all the controller models and AOS versions.
WebUI
  1. Navigate to Configuration> Stateful Firewall> Destination
  2. Click “Add”
  3. Enter IP version, Destination name and Destination description (optional).
  4. Enable “Invert” option if you want to specify all the destinations except the one configured in this netdestination
  5. Click “Add” at the bottom
  6. Add the new rule
  7. Click “add” and “Apply.
CLI
(Aruba-620) #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(Aruba-620) (config) #netdestination RDP-Host
(Aruba-620) (config-dest) #host 10.1.1.1
NOTE:  Please ensure you have PEFNG license installed on the controller to configure “netdestination”.
(Aruba-620) #show netdestination
Position  Type     IP addr  Mask-Len/Range
1         network  2000::   3
1         host  10.1.200.10   32
1         host  172.16.0.250   32
1         host  10.1.1.1   32
Version history
Revision #:
1 of 1
Last update:
‎07-16-2014 10:16 AM
Updated by:
Labels (1)
Contributors
