Why does VIA installation fail with error code 0x8004a029?
Environment  :  Any Windows 7 client with maximum network filters allowed
There maybe instances when VIA installation fails due to problem in installing VIA driver with error code 0x8004a029. This error occurs if there are too many network filtering applications that OS can handle.
Sample Logs from VIA logs (filename :: aninst.txt)
 ---snipped---
Feb 26 10:33:51.974  26fc  TRACE netcfgapi  399  Install finished...
Feb 26 10:33:51.975  26fc  ERROR netcfgapi  408  Install error 0x8004a029
Feb 26 10:33:51.975  26fc  ERROR netcfgapi  341  hrInstallComponent error 0x8004a029
Feb 26 10:33:51.975  26fc  ERROR aninsthelper  290  Couldn't install the network component
Feb 26 10:33:51.980  26fc  INFO aninsthelper  314  InstallSpecifiedComponent return 0x8004a029
Feb 26 10:33:51.980  26fc  ERROR aninsthelper  455  InstallSpecifiedComponent error 0x8004a029
Feb 26 10:33:51.980  26fc  INFO aninsthelper  463  ANInstallDriver return -1
Feb 26 10:33:51.980  26fc  ERROR aninsthelper  1674  Failed Installing IM driver -1
  ---snipped---
Cause ::
Microsoft limits the number of network filters which can be installed on Windows OS. For Windows ; the hard limit is set at 14 while the default is set to 8. When the set value is already reached; new driver wouldn't be able to install and fail with above error code.
Resolution ::
1)    If possible; uninstall other software which might have installed these network drivers. It is always recommended to keep the system clean by removing the software that is not being used. It is also a general understanding that many VPN like software have trouble interoperating with each other  in a single system (even when they are disabled not running ).
2)    Increase the maximum number of network filter drivers that can be installed in the system by changing the value in the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\MaxNumFilters.  Windows 7 is hard coded to allow 14 filter drivers, but the above registry sets the limit to 8 by default.  You can adjust the amount up to 14.
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 01:32 PM
Updated by:
Labels (1)
Contributors
