Advantages of Restricted Corporate accessFeature in IAP
Environment- Tested in 4.1.1.2 version.
Answer- 1. IAP  supports corporate access from upstream devices using the master AP as the VPN gateway.
2. In single AP VPN deployments/GRE tunnel using a shared unmanaged switch, this can be exploited by rogue clients/IAPs to gain corporate access.
3. This feature provides a way to restrict corporate access (through VPN tunnel ) to clients/Slave APs on upstream.
4: This feature provides frestricting any unwanted Traffic eg(STP brodcast )  to flood over the tunnel causing port block issue  on uplink .
CLI configuration:-
Master (config) # restrict-corp-access
Master (config) # end
Master# commit apply
GUI Configuration
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 10:59 PM
Updated by:
Labels (1)
Contributors
