Bypassing Controller discovery in UAP
MVP
MVP
Q:
Question : How to bypass Controller discovery in UAP?
A:
In apboot type the below command to bypass controller discovery:
setenv uap_controller_less 1
you can confirm the same in bootup process also,
10.17.168.27 255.255.255.224 10.17.168.1
2001::f8/64 Scope:Global
ADP is disabled by uap_controller_less
At any point to confirm you have set up bypass controller discovery, when the UAP in IAP mode you can execute the below command:
70:3a:0e:c1:2e:72# show ap-env
Antenna Type:Internal
Need USB field:Yes
standalone_mode:1
iap_zone:test,test1
uap_controller_less:1
70:3a:0e:c1:2e:72#
To reset the master disocvery execute the below command:
setenv uap_controller_less 0
Version history
Revision #:
2 of 2
Last update:
4 weeks ago
Updated by:
Labels (1)
Contributors
