How do I disable hard resetting with the reset button on IAPs?
Product and Software: This article applies to all Aruba Instant platforms and versions.
IAPs that have a serial port have a "disable_reset_button" variable. When this variable is set to "yes", if a user presses the reset button, the IAP is not reset to factory defaults. The user must gain access to the serial port and remove that variable.
Commands in apboot:
purge
setenv disable_reset_button yes
save
boot
To re-enable the reset button, issue these commands.
purge
save
boot
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 04:18 PM
Updated by:
Labels (1)
Contributors
