Environment- This article applies to all Instant models and versions above -4.0.0.x
Answer- In instant we do have an option to SSH to any other device/SSH server.Below is the method to do it:00:24:6c:c8:68:98# show versionAruba Operating System Software.ArubaOS (MODEL: 105), Version 6.4.2.3-4.1.1.2Website: http://www.arubanetworks.comCopyright (c) 2002-2015, Aruba Networks, Inc.Compiled on 2015-01-15 at 08:03:57 PST (build 48114) by p4build00:24:6c:c8:68:98# show aps2 Access Points---------------Name IP Address Mode Spectrum Clients Type Mesh Role Zone 2.4 Channel 2.4 Power (dB) 2.4 Utilization (%) 2.4 Noise Floor (dBm) 5.0 Channel 5.0 Po wer (dB) 5.0 Utilization (%) 5.0 Noise Floor (dBm) Need Antenna Config From Port Config Id Config Csum Ext SSID Active Age---- ---------- ---- -------- ------- ---- --------- ---- ----------- -------------- ------------------- --------------------- ----------- ------ -------- ------------------- --------------------- ------------------- --------- --------- ----------- --------------- ---00:24:6c:c8:68:98 10.17.168.254* access disable 0 105 Portal - - - - - 44 22 20(good) -94(good) No none 1 1585 disable 8m:36s24:de:c6:cd:6c:36 10.17.168.251 access disable 0 105 N/A - - - - - - - - - No none 1 1585 disable 2m:17s00:24:6c:c8:68:98 10.17.168.254 ==> master24:de:c6:cd:6c:36 10.17.168.251 ==> slave00:24:6c:c8:68:98# ssh 10.17.168.251 user admin port 22Host '10.17.168.251' key accepted unconditionally.(fingerprint sha1 1b:70:4d:47:52:ea:00:ce:5f:0e:f9:db:db:04:d0:4a:42:fc:98:15)admin@10.17.168.251's password:=====[now we are in the SSH session of the slave as shown below]=========24:de:c6:cd:6c:36#24:de:c6:cd:6c:36# show ip interface briefInterface IP Address / IP Netmask Admin Protocolbr0 10.17.168.251 / 255.255.255.224 up up=====[to go back to the master IAP, execute the below command]========24:de:c6:cd:6c:36#24:de:c6:cd:6c:36# exit00:24:6c:c8:68:98#00:24:6c:c8:68:98# show ip interface briefInterface IP Address / IP Netmask Admin Protocolbr0 10.17.168.254 / 255.255.255.224 up up00:24:6c:c8:68:98#You can also ssh to controller or any other SSH capable devices.
