How to disable VHT on IAP?
We can disable VHT from the WebUI and CLI of the IAP by following the below steps:-
Click on the Network name --> Click on Edit --> Click on "Show Advanced Options" --> Uncheck "Very high throughput" under 802.11 and Click on Next and finish the wizard.
Login into the Virtual controller and follow the below steps:- 18:64:72:c9:c4:9c (config) # wlan ssid-profile <test-ssid> 18:64:72:c9:c4:9c (SSID Profile "test-ssid") # very-high-throughput-disable 18:64:72:c9:c4:9c (SSID Profile "test-ssid") # exit 18:64:72:c9:c4:9c (config) # exit 18:64:72:c9:c4:9c# commit apply committing configuration... configuration committed. 18:64:72:c9:c4:9c#
18:64:72:c9:c4:9c# show ap bss-table Aruba AP BSS Table ------------------ bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t --- --- ---- -- --- ---- ---------------- ------ ------- ------- ----- 18:64:72:1c:49:d0 test-master ?/? 10.17.170.248 a-HT ap 36+/15/22 0 18:64:72:c9:c4:9c 0 8h:11m:34s 18:64:72:1c:49:c0 test-master ?/? 10.17.170.248 g-HT ap 11/9/21 0 18:64:72:c9:c4:9c 0 8h:11m:33s Channel followed by "*" indicates channel selected due to unsupported configured channel. "Spectrum" followed by "^" indicates Local Spectrum Override in effect. Num APs:2 Num Associations:0 18:64:72:c9:c4:9c#
18:64:72:c9:c4:9c# show running-config | begin "wlan ssid-profile" wlan ssid-profile test-ssid enable index 0 type employee essid test-ssid wpa-passphrase 7c597d65d9093b6b9436547389ca7b46c306ebde2ba25577 opmode wpa2-psk-aes max-authentication-failures 0 vlan 10 rf-band all captive-portal disable dtim-period 1 broadcast-filter none dmo-channel-utilization-threshold 90 local-probe-req-thresh 0 max-clients-threshold 64 very-high-throughput-disable
