Chromecast is a thumb-sized media streaming device that plugs into the HDMI port on your TV. Set it up with a simple mobile app, then send your favorite online shows, movies, music and more to your TV using your Laptop, smartphone and tablet
Chromecast offers two methods to stream content to a television. The first employs Chromecast-enabled mobile apps and web apps; second can mirror most content displayed by the web browser Google Chrome running on a personal computer, as well as content displayed on some Android devices.
Chromecast is supported with the following operating systems, although some of its features may work with slightly older OS’s in a few cases:
Android Gingerbread 2.3 or higher.
Chrome OS (Chromebook Pixel on Chrome 28 or higher).
iOS 6.0 or higher (on iPhone, iPad and iPod).
Mac OS 10.7 or higher.
Windows 7 or higher.
Environment :
Network Topology :
Configuration Steps :
After you input the TV it will prompt will below setup screen
From you Laptop download the setup file to connect to Chrome http://google.com/chromecast/setup
Connect to the Chrome SSID from the Laptop
Run the Chromecast Downloaded file to proceed
Confirm the Code that appears on the TV screen as show below.
Browse to Configured instant SSID which appears on the screen.
Successfully connected window will appear from the Chrome app and we should be ready to cast.
TV would show up with the following message and we should be ready to cast it.
On Laptop now on your chrome browser we should see the your Chrome ready to cast so select it
