Environment : This article applies to Aruba Instant Access Points running Aruba InstantOS 3.3 or higher.
Configuration changes in an IAP cluster is centralized on Master IAP and it assigns a cfg_id(Configuration ID) to every different configuration change that occurred. If the Slave IAPs cfg_id is different with master, master should send recorded configuration to the slave Instant AP. On receiving configuration message from Master, Slave updates the configuration and then its owncfg_id.Due to load or congestion on the network, configuration synchronization issues might rise up between Master and Slave IAPs. First steps in troubleshooting sync issues is to look at the config_id on Master and Slave.Run the below command to view the config_id on Master or Slave IAP:#show delta-config
