Q: Is it possible to disable UAPSD knob in IAP?
A: Is it possible to disable UAPSD knob in IAP?
Prior to 4.2.1, the UAPSD was supported with being enabled by default, but there was no user interface to disable it.
From 4.2.1 we provide a CLI interface to disable or enable it when needed.
The UAPSD configuration only supports on wlan-ssid-profile.
To Disable UAPSD:
IAP (config) # wlan ssid-profile test
IAP (SSID Profile "test") # wmm-uapsd-disable
To Enable UAPSD:
IAP (SSID Profile "test") # no wmm-uapsd-disable
