Use of Controller filed on Activate.
Q:
Why does activate shows different mac address in the flied "Controller", when actual mac address of the device is already displayed in the field "Mac"?
A:
Activate can be used to pull several information about the device in the cluster such as it's mode, part number, device's mac address using it's serial number or vice versa, cluster size, activate id, firmware information, etc. The field "Controller" on activate always displays the VC's mac address whereas the field "Mac" will always show the mac address of the device WLAN user is searching for.
In the below example we used a slave AP's serial number to find it's information but it also shows the VC's mac address in the field "Controller" to which it's forming a cluster. Using this WLAN user can get more information about the VC by searching it's mac address again on activate.
Serial:
CF0287009
MAC:
40:EE:D6:C2:CE:8C
Part Number:
IAP-215-RW
Mode:
IAP-SUB
Platform:
Centaurus
Current FW:
6.4.3.1-4.2.0.3_52603
Boot Version:
1.5.3.9.43867
Controller:
40:E3:D6:C1:CE:EA
Devices Associated:
8
Status:
provisioned
First Seen:
1/4/2016 8:48 PM
Last Modified:
1/20/2016 5:29 PM
Last IP:
203.38.238.129
Activation ID:
Current Customer:
Australia Post
Folder:
athena-f-8001588
Rule:
iap_to_athena
AP Name:
Now when searched using VC's MAC address, we got all the details about the VC and the field "Controller" has the same mac address as the field "Mac". This is the only scenario mac address in the field "Mac" and "Controller" will be same.
Serial:
CF0287056
MAC:
40:E3:D6:C1:CE:EA
Part Number:
IAP-215-RW
Mode:
IAP-VC
Platform:
Centaurus
Current FW:
Boot Version:
1.5.3.9.43867
Controller:
40:E3:D6:C1:CE:EA
Devices Associated:
8
Status:
provisioned
First Seen:
1/4/2016 2:09 PM
Last Modified:
1/20/2016 5:29 PM
Last IP:
203.38.238.129
Activation ID:
CA9QCYRT
Current Customer:
Australia Post
Folder:
default
Rule:
AP Name:
Version history
Revision #:
2 of 2
Last update:
‎08-08-2016 12:05 PM
Updated by:
Contributors
