last person joined: 9 hours ago
80 MHz Channels and VHT
  • 1.  80 MHz Channels and VHT
    Posted Jul 14, 2016 12:51 PM
    In reference to an IAP-215.
    I am operating in an environment where I don't want to use 80 MHz channels.  I have removed 80 MHz support (not seeing any xxE connections so that is fine).
    However in the bss-tables I am seeing a-VHT instead of a-HT for my SSID profiels.  Is there any problem in disabling 80 MHz, but still having VHT active?
    Thanks!
  • 2.  RE: 80 MHz Channels and VHT
    Posted Jul 14, 2016 12:54 PM
    VHT means 11ac. 802.11ac can be used with 20 and 40 MHz channels as well.
  • 3.  RE: 80 MHz Channels and VHT
    Posted Jul 14, 2016 12:56 PM
    'show ap active'
    if you see a '+' or '-', then it's 40Mhz. If you see an 'E' then it's 80 MHz.
  • 4.  RE: 80 MHz Channels and VHT
    Posted Jul 14, 2016 01:04 PM
    Yes, I know (+) and (-) channels are 40 MHz and (E) are 80 MHz.
    Just wanting to confirm that there is no problem with having both 40 MHz and still seeing a-VHT in the BSS table.
    For reference, only expecting 802.11n clients connected to the SSID.
  • 5.  RE: 80 MHz Channels and VHT
    Posted Jul 14, 2016 01:12 PM
    Ah gotcha, then yea no issues, VHT40 and VHT20 are fine and will support 11n clients no problem.
  • 6.  RE: 80 MHz Channels and VHT
    Posted Jul 14, 2016 01:19 PM
    Thank you!  My paranoia just needed to be satisfied.
