802.1x and NPS2012
Attempting to enable PEAP Authenication using NPS 2012.
Users are able to access networks successfully when using aruba provided certificate and termination enabled.
However, when attempting to switch the certificate over to 3rd party - digicert on NPS server we are unable to authenticate.
Any suggestions?
We are running IAP 225s with 6.3.1.4
Successful Attempt Termination Enabled
Log Name:      Security
Source:        Microsoft-Windows-Security-Auditing
Date:          8/5/2014 1:53:36 PM
Event ID:      6272
Task Category: Network Policy Server
Level:         Information
Keywords:      Audit Success
User:          N/A
Computer:      server1.ewg.lan
Description:
Network Policy Server granted access to a user.
User:
Security ID: Domain\Test
Account Name:test
Account Domain: Domain
Fully Qualified Account Name:Domain\test
Client Machine:
Security ID:NULL SID
Account Name:-
Fully Qualified Account Name:-
OS-Version: -
Called Station Identifier:18:64:72:C7:A2:14
Calling Station Identifier:0C:60:76:24:98:4B
NAS:
NAS IPv4 Address:192.168.70.25
NAS IPv6 Address: -
NAS Identifier:-
NAS Port-Type:Wireless - IEEE 802.11
NAS Port:0
RADIUS Client:
Client Friendly Name: MT 70 VC
Client IP Address: 192.168.70.25
Authentication Details:
Connection Request Policy Name: Secure Wireless Connections - 802.1x
Network Policy Name: Secure Wireless Connections - WiFiStudent - Secure
Authentication Provider: Windows
Authentication Server: server1.domain.lan
Authentication Type: MS-CHAPv2
EAP Type:-
Account Session Identifier:-
Logging Results:Accounting information was written to the local log file.
Quarantine Information:
Result:Full Access
Fail Attempt Termination Disabled
Audit Failure8/5/2014 2:02:50 PMMicrosoft Windows security auditing.6273Network Policy Server
Log Name:      Security
Date:          8/5/2014 2:02:50 PM
Event ID:      6273
Level:         Information
Keywords:      Audit Failure
User:          N/A
Computer:     Server1.domain.lan
Description:
Network Policy Server denied access to a user.
Contact the Network Policy Server administrator for more information.
User:
Account Name: test
Fully Qualified Account Name: Domain\test
Client Machine:
Security ID: NULL SID
Account Name: -
OS-Version: -
Called Station Identifier:18:64:72:C7:A2:40
NAS:
NAS IPv6 Address: -
NAS Identifier:192.168.70.36
NAS Port-Type: Wireless - IEEE 802.11
NAS Port:0
RADIUS Client:
Client IP Address:192.168.70.25
Authentication Server: Server1.domain.lan
Authentication Type: EAP
EAP Type: -
Account Session Identifier: -
Logging Results: Accounting information was written to the local log file.
Reason Code: 22
Reason: The client could not be authenticated  because the Extensible Authentication Protocol (EAP) Type cannot be processed by the server.
Re: 802.1x and NPS2012
Are the clients' wireless settings configured using Group Policy?
Tim Cappalli | Aruba Security
They are not.
With termination enabled - clients are prompted for the certificate if they do not already have it.
After disabling termination we have tried manually providing access to the new certificate.
No luck.
Is the EAP type specified under the wireless settings on the client?   (PEAP/EAP-MSCHAPv2)
Making Progress - on OSX 10.9
Manually setting this now prompts to install the certificate from NPS server.
Selecting Show Certificate shows the root certificate is not trusted:  This root certificate is not trusted
Log Name: Security
Date: 8/5/2014 4:28:33 PM
Event ID: 6273
Level: Information
User: N/A
Computer: Server1.ewg.lan
Description:
User:
Security ID: Domain\test2
Account Name: test2
Fully Qualified Account Name: Domain\TEST2
Client Machine:
Account Name: -
Fully Qualified Account Name: -
OS-Version: -
Called Station Identifier: 18:64:72:C7:A2:14
Calling Station Identifier: 64:76:BA:AC:74:92
NAS:
NAS IPv4 Address: 192.168.70.25
NAS IPv6 Address: -
NAS Identifier: 192.168.70.32
NAS Port: 0
RADIUS Client:
Network Policy Name: Secure Wireless Connections - WiFiStaff - Secure
Authentication Server: Server1.ewg.lan
Authentication Type: PEAP
EAP Type: -
Reason Code: 23
Reason: An error occurred during the Network Policy Server use of the Extensible Authentication Protocol (EAP). Check EAP log files for EAP errors.
We are now also getting this event generated as well.
Log Name: Security
Date: 8/5/2014 4:35:11 PM
Event ID: 5061
Task Category: System Integrity
Level: Information
User: N/A
Description:
Cryptographic operation.
Subject:
Security ID: SYSTEM
Account Name: Server1$
Logon ID: 0x3E7
Cryptographic Parameters:
Provider Name: Microsoft Software Key Storage Provider
Algorithm Name: RSA
Key Name: domain-SERVER-CA-1
Key Type: Machine key.
Cryptographic Operation:
Operation: Decrypt.
Return Code: 0x80090010
Here is a tutorial that show you how to configure instant + windows 2012 server
The extra thing you will find in this tutorial would be that you are usind derived roles in it
http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/tutorial-802-1X-with-Server-Derived-user-role-Instant-Windows/m-p/146084
Here is the tutorial which show you how to configure the client
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Correctly-configure-EAP-PEAP-Windows-client/td-p/43398
Here is a video as well
https://www.youtube.com/watch?v=-SmeubOR9aE
Cheers
Carlos
Alternetworks Corp
Are the root and intermediate certs installed on the NPS server?
If he is using a 3rd party certificate he just should install that certificate in the NPS serrver and put it in personal  certificate store.
If it not there  it will not work.
Also what kind of certificate do you have?
Did you installed it correctly under the personal certificate store?
Cheers
Carlos
Alternetworks Corp
We are using a digicert certificate.
I am also attempting using ADCS generated cert and receiving the same security log events.
Both are located under personal certificates.
***EDIT***
Will I need to import both the certificate and root certificate on the client or only the certficate?
Where should the root and cert be placed on the NPS server?
