AP-304 /IAP-92 and AP-ANT-16
  • 1.  AP-304 /IAP-92 and AP-ANT-16
    Posted Jul 17, 2017 06:08 AM
    I was searching for information concerning the antenna connectors on AP-304 vs. IAP-92.
    The reason is, that we are going to replace some IAP-92s to AP-304s and as much as possible we'd like to keep the AP-ANT-16 antennas.
    All I could find was RP-SMA for both models. Can I trust this information, and rely on it? I would avoid a situation where it turns out that SMA converters have to be used.
    Please point me into the right direction.
    Levente
  • 2.  RE: AP-304 /IAP-92 and AP-ANT-16
    Posted Jul 17, 2017 09:01 AM
    Both APs have RP-SMA, and will work with the ANT-16. The 304 will use all three leads though, so hopefully the 3rd leads were not cut off :)
  • 3.  RE: AP-304 /IAP-92 and AP-ANT-16
    Posted Jul 17, 2017 09:05 AM
    Thank you Jerrod,
    I do hope the 3rd lead was tucked in somewhere and we can pull it out and use it now... :-)
