you should be able to downgrade the firmware through Aruba Central. Just go to the firmware section and once you click Update Firmware, select the Other option for Firmware Version. You can then select which version you want including earlier ones.
If that doesn't work, then you can unlicense the affected APs, download an earlier firmware version from support.arubanetworks.com, and apply it manually through the AP's web interface.
