  • 1.  AP205 signal
    Posted Aug 02, 2017 04:19 AM
    Is it normal for AP205 signal like this? I put my phone very close to AP205 and use wifi tool for signal measurement. Its show only 40.
    I just change controller from model 6000 to Aruba7220 . Not sure anything relate to make it less stronger signal or not (such as setting signal strength....etc)
  • 2.  RE: AP205 signal
    Posted Aug 02, 2017 04:41 AM
    That is -40.
